Sunbeam EM 6910 rubber seal
Hi forum
I recently replaced a few parts on my Sunbeam EM 6910. Silicon drip stopper, silicon drip spring and the rubber seal (blue).
Since the replacement the handle grip won't stop at a 90 degrees angle but rather go all the way to the end of the cylinder which probably reduces the right pressure.
Is this a know issue with replacement rubber seals? anything I can do to achieve stronger handle pressure (maybe a spacer?)
Thanks
Mica
