Suzique
Your system is ready to go.
You also have a little work to do
1: It has had a leak at some stage and some water may have started some corrosion around the key pad.
Working for me at this point in time.
2: Both shower screens need work... I am too old and blind... needle work needed. (a point that many miss)
3: Very tight to lock in but I think due to the new style / improved collar.
4: The sweet spot is at 12.
5: HW wand dirty... This is not for steaming or frothing hot chocolate drinks
Every thing else considered a machine in good condition...
PS. You will need to off set the OVERDOSING with quality beans and the right grind and dose level
