rancilio epoca rebuild!
Not sure if it counts as a rebuild - more like a remodeling - but I've replaced the plastic sides with custom stainless plates, and the plastic front panel and rocker switch with a fitted dark plastic 'screen' and a new brew switch
Plus I've replaced the steam wand with something a little more industrial,  including a synesso steam tip - and the steam pressure is easily twice as good as original !
Photos don't really do it justice coz it's nestled in a pretty tight position - but it does make excellent coffee!
  • Nice.  The panels seems to fit well and suit the machine.  I'm sure they will last longer than the plastic!
  • on 1424170220:
    Thanks I bought the machine 2nd hand it was about 18th months old when I bought it and in good condition - but when I picked it up to put in the car the side panels fell off ! So I replaced those straight away with some custom ones that bolt on and can be easily removed for access Same thing happened to the front panel, and I quite like the exposed surfaces around the tap handles its been idle for awhile as there were some wiring issues but now everything is sorted and it's making great coffee !
  • hey, do you still photos? I'm in the process of a rebuild myself and the prior owner broke and threw out the plastic side and front panels. Would love to see how you did it.
    No sorry I sold the machine to a friend it's still working well but no photos sorry - it's simply a matter of cutting some sheet metal.to.size, rounding off any sharp edges. then bolting it on!
