Sign In RegisterIt looks like you're new here. If you want to get involved, click one of these buttons!
The Londinium I specs that I've found so far are as follows.What is the philosophy behind this project?
Londinium I will deliver the taste excellence of the Bosco
Londinium I will be a reservoir machine, that is to say, it will not need to be plumbed into the mains
Londinium I will set a new benchmark in engineering excellence for domestic espresso machines and will utilise excellent materials with best in class fit and finish
The primary objective is to bring to market a lever espresso machine that delivers consistently excellent results in the hands of a user who is relatively new to espresso, not a cantankerous beast that delivers a great shot with seemingly no rhyme nor reason. Thermal stability of the group is therefore the datum for this project. Until this is achieved Londinium I will not enter production.
As a result it is intended to appeal to a broad audience and not just appeal to espresso freaks. For this reason it will have a hot water port for americanos and instant preparation of other hot drinks such as teas and hot chocolate without having to boil a kettle separately. It will also be intended to be left on all day so it is ready to go whenever you feel like a hot drink. It will also feature an oversize element so it reaches operating temperature quickly enough for it to be used on a working day as you rush to work - too many machines are only used at the weekend as they take too long to heat up.
In conjunction with these objectives Londinium I will have a reservoir so the boiler can be filled without having the inconvenience and danger of having to switch off the machine and bleed the pressure from the boiler, as you do with an Olympia Cremina. This of course comes at a cost; as a result the machine will need to be larger, but then we need sufficient mass at the rear of the machine to act as a counter-balance to the force of the spring lever, so the need for a reservoir is kind of forced upon us anyway. Nonetheless, we will be pushing the design envelope very hard to keep the footprint of the machine as small as possible
Additionally there will be a particular design focus on ensuring the group does not cool when the machine is idle. For this reason a thermosiphon will be added and the group will be mounted as close to the boiler as we can
Finally, it will be an object of beauty, as we are well aware that more than one person is typically involved in the decision to purchase any item that sits anywhere near the kitchen. Plastics will be limited to applications where they are they most sensible solution, for example, the knobs.
It will be a timeless design and model changes will be as infrequent as possible, much in the manner of the Olympia Cremina design philosophy.
We look forward to publishing images of the prototype here as soon as it is completed. We expect to see it by the end of June.
Londinium Espresso are proud to support British manufacturing with the creation of the Londinium I spring lever espresso machine
ps - the target selling price for Londinium I is GBP1500 including VAT. we will be trying very hard to stick to this number to ensure the machine is accessible to as many people as possible, in particular those considering a prosumer pump machine.
We will have a prototype for the first week of July, which most likely will not have any bodywork/decorative bits finalised as these are somewhat secondary to how the machine performs, which needs to set new standards
Upon receiving the prototype we will publish an extensive gallery of images on the blog here so you can get a good idea of what is on offer
Don't expect any new technology, dials, or electronics. Along with many of you, we have proved beyond all reasonable doubt that this is not the way forward in espresso, contrary to the opinion of some influential industry figures
Londinium I is simple. It takes the same magnificent group that is used on the Bosco, and indeed by Kees Van der Westen, with the optional thermosiphon feature specified. Then it deploys it in a compact configuration that is suitable for the home and small business use. The machine has a reservoir, so it does not need to be connected to the water mains
Such a machine is not currently available in the marketplace, to the best of our knowledge
The cornerstone of the project will be engineering excellence, something which in our observation is more scarce in espresso machines than the industry would have you believe. Londinium I is intended to be a machine that will serve you for a lifetime with best in class espresso
The choice of a spring lever, and the steps taken to ensure the group heats up quickly and evenly and maintains a stable temperature will also ensure that unlike many other lever machines it will be relatively easy for inexperienced users to achieve very good results. We see this as being critical to the machine's success in the market
The choice of group ensures the taste will be magical, just as the Bosco & Kees' idrocompresso is. Unlike the Bosco the group will be mounted directly to the boiler, and like the Idrocompresso the group has been specified with a thermosiphon. Whilst a thermosiphon ensures the group temperature does not drop when the machine is idle, it also has another purpose; it ensures the group heats quickly, evenly and thoroughly when it is switched on. We think this is an essential feature in a machine that will often be switched on for a short period of time for a couple of espresso before work, then switched off again
We also hope to add some visual appeal to the machine after we have confirmed that the performance of the prototype is everything we hope it will be
The prototype will be subject to some fairly rigorous testing and will be available to any existing customer to come and have a play with
The target is to turn around the feedback from the prototype and finalise the bodywork, with a view to having a finished product on the shelf and awaiting order for the first week in September so the machines are continuously available for purchase in the all important run up to Christmas.
