Hi
I'm considering purchasing a Ponte Vecchio Lusso 1 group from Italy, and have been reading threads here and elsewhere about this machine. I'm wondering what advice both current and previous owners of this Lever have after owning one?
- It appears the batch that Jack at Sorrentina imported had issues with the group which was diagnosed as faulty seals, yet from what I have read .. there has also been a problem with scoring of the piston .. which may have been the cause of the leaking from the group rather than faulty seals? I'm wondering whether the leaking has been fixed by changing the seals .. or whether after a short time the problem has returned .. which would suggest that either there is/was a manufacturing fault with the machining of the pistons or possibly the piston shaft is scoring the surface when the lever is being used?
As owners would have probably already changed seals .. has the surface been checked for scratches?
I'm trying to find out how prevalent the problem of leaking groups is .. and what owners have done to rectify this?
It has been suggested that if the scoring is only superficial, that a 'honing' attachment for a power drill (from Repco) can be used to polish the surface of the piston. Another suggestion was to get the piston chromed. Is this a good idea or would this cause a problem with the lever shaft fitting?
Are people generally happy with their PV Lusso regardless of their flaws? I'm wondering whether I should take the risk on getting one .. or save up and get a better lever machine like the Strega or Achilles. Even after laying out the extra $ for a better quality machine doesn't guarantee it won't have a niggle or two of its own. From what I've been reading, the Achilles has a few flaws of its own in the design department?
Another suggestion for the Lusso is to use a varnish, say Estapol? on the inside of the cover to guard the metal against rust .. being in a hot .. possibly humid environment?
I'm also thinking about insulating the boiler with something like 'Insulbrite' to guard the plastic on the electric cables attached (or in close proximity) to the boiler from melting?
I would appreciate any advice on this.. even comments like - 'forget it ::) .. the sooner you aim higher, the better off you'll be.. as in, I had one once and glad I have upgraded to something better.
Cheers :thumb:
